I am trying to perform a shape analysis on a dataset of strictly 2D femur contours using .vtk files in ShapeWorks Studio. However, I am completely stuck at the transition between Grooming and Optimization.
Here is a quick summary of the issue:
1. Mesh Grooming completes but something is missing: I load my 2D .vtk files and run the standard Mesh Grooming pipeline. The process finishes without crashing, but it seems it doesn’t generate the data the optimizer is expecting.
2. “Run Optimize” is permanently disabled: When I move to the Optimize tab, the Run Optimize button remains completely grayed out, making it impossible to generate the particles. I have tried saving the project and reloading it, but the button stays locked.
My question: I suspect the software is blocking the optimization because my meshes are strictly 2D (the Z-axis is flat/zero). Is there a specific, recommended workflow to process purely 2D .vtk data in ShapeWorks Studio? For my 2D femur contours, is .vtk the correct format to use in ShapeWorks? Is there a setting I am missing to force the Optimizer to work in a 2D plane, or do I need to artificially extrude my contours into 3D volumes first?
So the problem is likely your region/language settings. It’s marking the initial relative weighting as invalid because it’s expecting a comma instead of a period for the decimal.
The easiest way to fix this is to install the development version of ShapeWorks that includes a fix for this.
Alternatively, you can set your region/language settings to US.
Hi again,
Thank you very much for the response. I installed the pre-release as suggested, but I am now getting different errors with my strictly 2D .vtk files. When I run the Grooming step, it seems the tool is deleting the geometry completely.
Specifically, if I run it with Alignment checked, the logs show:
Warning: Empty mesh in createICPTransform: source has 0 points, target has 0 points - returning identity
Error: meshes must have points
Error: Generated mesh is empty, file: groomed\Paciente04_FU0_groomed.vtk
To troubleshoot, I tried running it with Alignment disabled (and all other filters off), but I still get this error:
Furthermore, if I try to skip the Grooming step entirely to see if it bypasses the issue, I get this error instead:
Error: Mesh construction failed: Unable to warp mesh. Further messages will be suppressed
Could this issue be related to the nature of my data? My .vtk files are strictly 2D outlines/contours of the femurs (just the boundary lines with no internal filling or volume). Is it possible that the grooming/warping algorithms are failing or collapsing the data because they expect a filled surface or 3D surface rather than a 2D empty contour?
Is there a specific way I should format these 2D contours for this pre-release version to prevent the geometry from being deleted?
Thank you for your help!
I see, yeah, the grooming for contours got broken in a recent update. I’ve just merged a fix for this and new builds are available here:
