Hello!
Does shapeworks support shape model for 2D shape analysis (Contour based cases)? In the ‘Use cases’ it seems to be OK to analysis shape model for contour domains. But when i import 2D data, Errors jumped out suggesting that the data must be 3D.
The types of contours we are currently supporting are as a series of points/lines in VTK files.
Are you trying to use a 2D image segmentation? If so, we can investigate a way to convert it.
Yes,we tried to use 2D shape image segmentation,which was acquired from
3Dslicer. The file format is nrrd and the image is a 2D plane rather than some lines. Is there any tools to convert it?Thank you!
---- Replied Message ----
From | Alan Morris via ShapeWorksnotifications@shapeworks.discoursemail.com |
Date | 09/08/2022 01:52 |
To | xbyzju@126.comxbyzju@126.com |
Cc | |
Subject | [ShapeWorks] About contour domains |
| amorris
September 7 |
The file format is nrrd,a 2D shape segmentation from 3Dslicer.
From | Shireen Elhabian via ShapeWorksnotifications@shapeworks.discoursemail.com |
Date | 09/08/2022 00:00 |
Cc | |
| shireen Leader
September 7 |
Yes, ShapeWorks supports contour data, what file format are you using? @amorris
I believe the vtkContourFilter can do this for 2D, but I don’t know that there is a ready-made tool to convert this at the moment.
https://kitware.github.io/vtk-examples/site/Cxx/Visualization/LabelContours/
Thank you very much,I will try it.
Date | 09/09/2022 00:24 |
Cc | |
| amorris
September 8 |
