Multiple Domain SSM - left-sided reflection
I am currently working on figuring out Multiple Domain SSM. I have the data inputted (hemipelvis, sacrum, femur), however under the groom tab it only gives me the option to reflect one shape. Is there any solution to allow for all the left-sided bones to be reflected to the right? I did try using an outside program, but when I imported these into the Multiple Domain SSM function the bones were no longer “fitting” together. If anyone has experience with using the Multiple Domain function that would be greatly appreciated!
-Thanks!
In order to use the reflection functionality, add a column to your project spreadsheet (xlsx) to indicate which ones should be reflected, for example:
side
left
left
right
right
Then in the groom option for reflection, you can choose “side” = “left”.
Does that make sense?
Yes, that worked! Thank you!
