When I groom the instance model,the shapeworks studio reported an error:Unable to create groom output directory: “./groomed”.Is there any solution to this error? I would appreciate it if you could help me solve it.
Can you check the groomed output folder name in preferences?
Thank you very much! I have solved the problem after renstallation the shape works studio.Thank you again for your reply.
