After going through the multiple domain use-cases, I started developing a multiple domain SSM for pediatric forearms. Initially, I used ShapeWorks Studio, but I quickly noticed that the results were not properly aligned – the groomed data was simply not usable for optimization.
To address this, I implemented the grooming steps (smoothing, reflection, alignment) in a custom Python script, based on the Python examples from the multiple domain use-case. This approach surprisingly did produce well-aligned, usable data for the Optimize step.
I then returned to ShapeWorks Studio to tune the parameters and visualize how the particles were distributed. I started with a small sample and a low number of particles, gradually increasing both. Eventually, I ran into the same issue described in this thread: www.shapeworks.discourse.group/t/difficulties-tuning-particle-optimization-parameters/191.
What I’m observing now is that ShapeWorks Studio does not produce the same results as when I run ShapeWorks via a Python script – even when using the same default parameters. The differences are significant: the Studio output is worse, while the Python output is reasonable (see attached images).
