Hello!, I’m trying to use shapeworks via the python API, but I’m having trouble with getting the transform / alignment right. My issue is similar to this topic, but the advice from there has not solved it.
I’ve set up a simple script to demonstrate my issue. My use case is roughly similar to the hip_multiple_domain example, but when I run it with some test meshes, the alignment looks wrong in shapeworks studio (see the image) and the model output is garbage.
Interestingly, when I go back to the groom menu in shapeworks studio and run with just the alignment box ticked, everything works.
Here is my code:
import shapeworks as sw
from glob import glob
from pathlib import Path
import numpy as np
import subprocess
import pyvista as pv
import os
def main():
data_dirs = [Path("data/001"), Path("data/002")]
for data_dir in data_dirs:
if not os.path.exists(data_dir):
os.makedirs(data_dir)
# Create meshes
mesh_1_left = pv.Sphere(radius=1.5, center=[-2, 0, 0]).scale([1, 1, 1], inplace=False)
mesh_1_right = pv.Sphere(radius=1.5, center=[2, 0, 0]).scale([1, 1, 1], inplace=False)
mesh_2_left = pv.Sphere(radius=1.5, center=[-4, -1, 0]).scale([1, 1, 1.5], inplace=False)
mesh_2_right = pv.Sphere(radius=1.5, center=[1, -1, 0]).scale([1, 1, 2], inplace=False)
mesh_1_left.save(f"{data_dirs[0]}/left.vtk")
mesh_1_right.save(f"{data_dirs[0]}/right.vtk")
mesh_2_left.save(f"{data_dirs[1]}/left.vtk")
mesh_2_right.save(f"{data_dirs[1]}/right.vtk")
# Find reference
all_mesh_files = []
mesh_files = glob(str(data_dir / "*"))
all_mesh_files.append(mesh_files)
domains_per_shape = [len(files) for files in all_mesh_files][0] # 2 Files in each data directory
# Find the combined reference mesh
all_meshes = [sw.Mesh(file) for file in np.array(all_mesh_files).ravel()]
ref_index, combined_meshes = sw.find_reference_mesh_index(all_meshes, domains_per_shape)
combined_reference_mesh = combined_meshes[ref_index]
# Find the individual domain meshes at the reference mesh index:
# find_reference_mesh_index destroys all_meshes during the combining process. So we have to create them again
domain_reference_meshes = []
for i in range(domains_per_shape):
domain_reference_mesh = all_meshes[ref_index * domains_per_shape + i]
domain_reference_meshes.append(domain_reference_mesh)
# Compute transforms
all_combined_transforms = []
all_domain_transforms = []
meshes = [sw.Mesh(file) for file in mesh_files]
combined_mesh = meshes[0].copy() # Copy so we don't destroy meshes[0] for later!
for mesh in meshes[1:]:
combined_mesh += mesh
combined_transform = combined_mesh.createTransform(combined_reference_mesh, sw.Mesh.AlignmentType.Rigid,
10).flatten()
for mesh, ref_mesh in zip(meshes, domain_reference_meshes):
domain_transform = mesh.createTransform(mesh, sw.Mesh.AlignmentType.Rigid, 10).flatten()
domain_transforms.append(domain_transform)
all_combined_transforms.append(combined_transform)
all_domain_transforms.append(domain_transforms)
# Run optimize
params = {
"checkpointing_interval": 200,
"keep_checkpoints": 0,
"iterations_per_split": 2500,
"optimization_iterations": 200,
"starting_regularization": 1000,
"ending_regularization": 10,
"relative_weighting": 4,
"initial_relative_weighting": 0.03,
"save_init_splits": 0,
"verbosity": 0,
"use_normals": 1,
"normals_strength": 5.0,
"procrustes": 0,
"procrustes_scaling": 1,
"procrustes_rotation_translation": 1,
"number_of_particles": [32, 32]
subjects = []
for i, data_dir in enumerate(data_dirs):
subject = sw.Subject()
subject.set_number_of_domains(len(mesh_files))
combined_transform = all_combined_transforms[i]
domain_transforms = all_domain_transforms[i]
transforms = [*domain_transforms, combined_transform]
subject.set_groomed_transforms(transforms)
subject.set_groomed_filenames(mesh_files)
subject.set_original_filenames(mesh_files)
subject.set_display_name(str(Path(data_dir).stem))
subjects.append(subject)
project = sw.Project()
project.set_subjects(subjects)
parameters = sw.Parameters()
for key, value in params.items():
parameters.set(key, sw.Variant(value))
project.set_parameters("optimize", parameters)
spreadsheet_file = "sphere_test.swproj"
project.save(str(spreadsheet_file))
optimize_cmd = ("shapeworks optimize --progress --name " + str(spreadsheet_file)).split()
subprocess.check_call(optimize_cmd)
analyze_cmd = ('ShapeWorksStudio ' + spreadsheet_file).split()
subprocess.check_call(analyze_cmd)
if __name__ == "__main__":
main()
Can anyone help me understand this
