Hi all. I was wondering if it is possible to get individual mode scores for each model, such that I will know where each reconstruction lies within a given mode. Hoping to be able to group reconstructions based on where they exist along the +/- 2 standard deviations.
Hello. If I understand your question correctly, then yes it is possible. In ShapeWorks Studio, if you select File → Export → Export PCA Component Scores, then you will get a CSV file containing the scores for each of your samples. For example:
Here the first sample has a value of 52.835 for the first mode of variation, which is on the plus side. Zero will be the mean. If you need the value in terms of standard deviations, then you will probably have to calculate the SD value from the list of samples.
