Initialization vs. optimization steps
I’ve been using shapeworks quite a bit in the last couple of weeks. One thing I’ve noticed in my data, and it seems like in other posts here, is how to setup optimization that results in a consistent and smooth mesh after completion.
I use multiscale (=8 particles), normals (=4.0 strength), and procrustes which obviously helps correspondence throughout the optimization. However, I’ve also found using too large of iterations_per_split allows the particles to drift further out of correspondence with each step that doesn’t seem to be correctable with the optimization iterations. The scenario I’ve found to be a compromise is to use a quite small number of iterations_per_split (<=20, sometimes even =1). The particles don’t capture the full object in the early stages, but eventually with a large number of particles, do cover enough of it.
As an observation, it seems allowing particles to move a lot is good during the initial stages to capture the full object, but allowing too much drift later on is detrimental and leads to poor correspondence (topology) for the final shape.
I’m curious if when using multistage, it would make sense to limit the number of iterations_per_step(to =1) after hitting the multiscale_particles. At least intuitively it seems this could balance the initial object coverage while maintaining good particle correspondence.
I looked at the code, but don’t have enough cpp depth to make it a quick test on my part. Happy to share data if it’s helpful.
In general, it’s usually better to allow the initialization steps to fully represent the shape and have the particles be in correspondence. The Optimization phase isn’t really meant to fix correspondences, the goal here is to adjust the correspondence points to optimize for model compactness (e.g. in the PCA space). It kind of assumes that the particles are already in correspondence.
The approach I typically take is to increase the number of iterations per split and reduce the number of optimization iterations.
The multi-scale mode is a fairly advanced/complicated feature since it allows the optimization to run at each level. It’s tricky to get it to work correctly, but it can help with certain anatomies.
One way to separate the two effects is to run a small parameter sweep with multiscale on but fixed start/end particle counts, comparing your current small iterations_per_split against a moderate iterations_per_split with fewer optimization_iterations. Setting iterations_per_step to 1 after multiscale_particles may keep initialization correspondence from drifting, but it also gives the compactness term almost no chance to act, so the mesh can look smooth while the PCA model is worse. If you share the dataset and parameter file, correspondence quality and compactness can be compared rather than judged by mesh smoothness alone.
