Hi - I am a new ShapeWorks user and I am aiming to optimize & analyze images of tibiae, and hopefully use this to reconstruct some images as well.
Is working with an entire 3D model of a hollow bone (like a tibia) an issue? Is it better to perform separate analyses on the outer and inner surfaces?
The Surface Reconstruction tool - I am struggling to understand how to use it. Hoping for some help or a resource to guide me through it.
I appreciate any help! Thanks
Does your shape have inner and outer surfaces? Are you hoping to model the inner and outer surfaces together? This is possible and I believe has been done my a group before with ShapeWorks. You would need to extract the two surfaces as separate mesh files and use multi-domain optimization.
Whether a hollow tibia is a problem depends on the question: for whole-bone shape, use the outer surface only; for cortical thickness or medullary canal shape, model inner and outer surfaces as separate domains. If using both, extract two watertight meshes and run multi-domain optimization, keeping correspondence setup consistent between domains. For Surface Reconstruction, start from a clean binary/label volume, check voxel spacing, and inspect the resulting mesh for holes or artifacts before grooming. If the inner canal is not of interest, filling or excluding it is usually simpler than reconstructing both surfaces.
