Creating a MD-SSM for Subtalar Joint
Hi, I want to creating a MD-SSM for Subtalar Joint.
Currently, I would like to complete a preliminary experiment using ShapeWorks. I have 20 cases of talus and 20 cases of calcaneus from 10 individuals.
(All files are in STL format.)
The first problem I encountered was: how to import my STL model.
My method:
  1. I created an excel like below(Name: “Talus&Calcaneus”):
  2. I opened ShapeWorks 6.5.1, click “File” - “Open project” - select the excel which I just created (“Talus&Calcaneus”).
  3. Then I got the first Problem: why there is nothing in my screen?
Oh, furthermore all calcaneus bons and talus bones are saved in two different folders.
I tried a different approach:
by creating a “New Project,” importing five STL models of the talus, saving it as a Spreadsheet (xlsx), and manually editing this Excel file ( add a column for shape_2 along with the file location for the calcaneus).
Finally, when I opened ShapeWorks, I was able to obtain an image that combined the calcaneus and talus.
But, when I trying to save it, it shows like below:
Could you please tell me how to fix it?
Thx!
One more question~
At the beginning, the spatial positions and directions of the STL models we input were all different.
Should we align these models? If so, how should we proceed with the alignment?
the alignment part let me feels a bitconfused ; how should I choose?
I saw in your demo video that all the bones were in the same pose when they were introduced into the program.
Can you try saving as swproj (json) instead? I’m not sure what the xlsx zip stream problem is.
You can try setting the alignment to Iterative Closest Point, but this is generally for smaller misalignment. We don’t yet have tools in ShapeWorks to deal with very large misalignment. You might try aligning them manually in a different tool first.
Thank you for your reply, and it realy works!
( I mean saving as swproj format file)
Next, I continue to try to create MD-SSM.
In the Optimize section, my Settings:
After the run I encountered an error:
How can I fix this error?
The result of Optimize is shown in the figure below, I found that some models were not aligned very well (e.g. 009), will this affect the result?
Thank you very much for your help.
Could you please tell me how I can fix the error of particle vector?
Best regards,
Lyk
The above question still exists. However, when I try saving the software in “SWPROJ” format, the “Error” no longer appears, although I’m not sure if this counts as a resolution.
Also, after obtaining the “OPTIMIZE” results, I attempted to export the generated MD-SSM model. I right-clicked the model and selected “Export Mesh”
at this point the following error message appeared:
Do you know how to prevent this error from occurring, or what I should do instead?
Hope to receive your reply, thank you!
You can ignore the error about the particle vector size being different.
Yes, if some of the shapes are not well aligned, it will affect the result. You will have to examine the PCA modes to see.
Unfortunately, there doesn’t appear to be a stack trace in your error message that would help us track it down. However, it sounds very much like this:
This should be fixed in the development version of ShapeWorks:
Hello, it’s been a long time since we last communicated. I recently completed the MD-SSM for the four bones of the foot (the distal tibia, the distal fibula, the talus, and the calcaneus). However, the results didn’t look very good.
During the Optimize process, my settings were as follows:
During the Groom process, my settings were as follows:
I noticed that the distribution of the points was relatively even. I’m feeling a bit confused right now. Could you please tell me how I should make the correction?
I noticed that you replied under other people’s posts, suggesting to reduce the point setting and give it a try.
Keeping all other parameters unchanged, only changing “Number of Particles” to 128, the result is still acceptable (a crack appears on the inner side of the upper part of the tibia?), as follows:
When we change the Number of Particles, we got:
Apart from the abnormality at the fracture site of the tibia, wrinkles also began to appear on the surface of the calcaneus.
Hi @amorris
I adjusted the parameters of Optimize and the best result obtained is as follows:
However, there are still phenomena such as self-intersection, overlap, opposite directions of triangular facets, and some particles crossing (passing by) other particles during movement.
Could you please tell me how I should adjust the parameters?
I would suggest before looking at surface reconstructions to look at the correspondence particle configurations, since these are what are used to drive the surface reconstruction.
As for the parameters, I’m not sure I would recommend multi-scale mode and would start with a lower number of optimization iterations. If the particles are not in good correspondence when the optimization phase starts, it’s difficult for the optimization to fix all of them. I would be interested to see the particle configuration at the start of the optimization phase (e.g. 0 optimization iterations).
Following your suggestion, I have disabled the “Multiscale Mode” and set “Optimization Iterations” to 0. The result of running the program is:
I observed that: In the areas where the particles were previously set, there were often wrinkles and self-intersections. The particle distribution was not particularly good (for the same particle, in the same bone of different subjects, the particle correspondence was not particularly accurate. For example: the point on the Groove for Tendo of Flexor Hallucis Longus of calcaneus in the figure, there was an offset on the calcaneus of different people).
I think the next thing I would experiment with are increasing the normals strength so that it plays a larger role (perhaps 10)?
If that does not help, I would try enabling geodesics. It will be significantly slower, but may improve results.
