I would like to make some contributions to Shapeworks but am having trouble setting up a developer environment. I am running Windows 11 and trying to follow the instructions here. Here are the steps I have taken:
CMake, Visual Studio, and Anaconda are already installed. I forked the Shapeworks repository and cloned it to my PC.
With conda activated in Powershell, run install_shapeworks.bat. Then run conda activate shapeworks
In git bash, run ./build_dependencies. This resulted in an error: Could not find boost. I gather this is because install_shapeworks.bat does not install the developer dependencies.
So, in git bash, I activated conda, then ran source install_shapeworks.sh
Ran ./build_dependencies. Seemed to run fine this time. Took about 1 hour. The end of my build_dependencies.log looks like this:
Dependency paths:
VTK_DIR: /c/g/shapeworks_dev/dependencies/install/lib/cmake/vtk-9.1
ITK_DIR: /c/g/shapeworks_dev/dependencies/install/lib/cmake/ITK-5.2
EIGEN_DIR:
OpenVDB_DIR: /c/g/shapeworks_dev/dependencies/install/lib/cmake/OpenVDB/
LIBIGL_DIR: /c/g/shapeworks_dev/dependencies/install/libigl/cmake
GEOMETRY_CENTRAL_DIR: /c/g/shapeworks_dev/dependencies/install/geometry-central
ACVD_DIR: /c/g/shapeworks_dev/dependencies/install
## To configure ShapeWorks, create a build directory and from there run...
cmake -DCMAKE_CXX_FLAGS= -DCMAKE_PREFIX_PATH=/c/g/shapeworks_dev/dependencies/install -DUSE_OPENMP=ON -Wno-dev -Wno-deprecated -DCMAKE_BUILD_TYPE=Release /c/g/shapeworks_dev
real 60m24.389s
user 0m0.060s
sys 0m0.289s
Installed version 6.6.1 of open source QT. Added C:\Qt\6.6.1\msvc2019_64\bin to my Path environment variable.
Created a directory named build, then entered it and ran the exact cmake command from the build_dependencies output.
Ran start shapeworks.sln. In visual studio, set configuration to release. Build ran with 32 succeeded, 0 failed, 2 skipped.
Back in git bash, ran cmake -P cmake_install.cmake (Not sure if this is needed?) Redulted in error, cannot find C:\Windows\SysWOW64\vcruntime140_1.dll. Pasted this dll into this location from the ITK installation in conda. cmake script then ran fine.
Ran source …/devenv.sh ./bin/Release/
Ran ctest -C Release. Resulted in 40% pass:
Test project C:/g/shapeworks_dev/build
Start 1: ImageTests
1/10 Test #1: ImageTests ....................... Passed 61.40 sec
Start 2: MeshTests
2/10 Test #2: MeshTests ........................ Passed 25.21 sec
Start 3: GroomTests
3/10 Test #3: GroomTests .......................Exit code 0xc0000135
***Exception: 0.03 sec
Start 4: OptimizeTests
4/10 Test #4: OptimizeTests ....................Exit code 0xc0000135
Start 5: PythonTests
5/10 Test #5: PythonTests ......................***Failed 41.59 sec
Start 6: ParticlesTests
6/10 Test #6: ParticlesTests ................... Passed 6.10 sec
Start 7: ProjectTests
7/10 Test #7: ProjectTests .....................Exit code 0xc0000135
Start 8: UseCaseTests
8/10 Test #8: UseCaseTests .....................***Failed 13.29 sec
Start 9: shapeworksTests
9/10 Test #9: shapeworksTests ..................***Failed 6.65 sec
Start 10: UtilsTests
10/10 Test #10: UtilsTests ....................... Passed 0.04 sec
40% tests passed, 6 tests failed out of 10
Total Test time (real) = 154.41 sec
- Importing shapeworks in python results in the following error:
Python 3.9.13 | packaged by conda-forge | (main, May 27 2022, 16:50:36) [MSC v.1929 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import shapeworks
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "C:\g\shapeworks_dev\Python\shapeworks\shapeworks\__init__.py", line 5, in <module>
from shapeworks_py import *
ImportError: DLL load failed while importing shapeworks_py: The specified module could not be found.
