When performing batch processing of segmentation using Python, the groom stage encountered an exit139 error while executing the find_reference_image_index function. Currently, my solution is to manually specify an index, which is obviously too simplistic. By reviewing the source code, I found that the find_reference_image_index function performs a tomesh operation. Are there any optimization methods to control resource consumption?
The source code I used is as follows:
# -*- coding: utf-8 -*-
Full Example Pipeline for Statistical Shape Modeling with ShapeWorks
In this example, we provide unpre-processed left atrial dataset,
which consists of the LGE scan and its segmentation across some number of subjects.
Since the data set is not pre-processed, it requires all re-processing steps;
resampling, padding, alignment, etc. To run the ShapeWorks particle-based optimization,
the processed segmentation files are converted to the signed distance transform.
This example is set to serve as a test case for users who want to process the raw(gray-sclae)
images as well as their binary segmentation images.
First import the necessary modules
import os
import subprocess
import shapeworks as sw
import pandas as pd
os.environ['PATH'] = '/v16data/root/adg/packages/ShapeWorks-v6.5.1-linux/bin' + os.pathsep + os.environ['PATH']
print(os.environ['PATH'])
def Run_Pipeline():
print("\nStep 1. Acquire Data\n")
Step 1: ACQUIRE DATA
We define dataset_name which determines which dataset to download from
the portal and the directory to save output from the use case in.
# sampled_data = []
# behavior_data = pd.read_excel('../data/label_with_cog_filted.xlsx').values.tolist()
# for x in behavior_data:
# if x[5] == 0 and len(sampled_data) <= 100:
# sampled_data.append(x)
# if x[5] != 0 and len(sampled_data) <= 200:
# valid_names = [i[-2] for i in sampled_data]
# print(valid_names)
input_path = '/v16data/root/adg/python_projects/ventriclecal_brain_age/shapework/'
file_root = input_path + '3d_brain_ventricle_vol_smooth_nrrd/'
# file_list = sorted([file_root + i for i in os.listdir(file_root) if i in valid_names])
file_list = sorted([file_root + i for i in os.listdir(file_root)])
print(file_list)
print("\nStep 2. Groom - Data Pre-processing\n")
Step 2: GROOM
The following grooming steps are performed:
- Crop (cropping first makes resampling faster)
- Resample to have isotropic spacing
- Pad with zeros
- Compute alignment transforms to use in optimization
- Compute distance transforms
For more information about grooming, please refer to:
http://sciinstitute.github.io/ShapeWorks/workflow/groom.html
# Create a directory for groomed output
groom_dir = input_path + 'groomed/'
os.makedirs(groom_dir, exist_ok=True)
We loop over the shape segmentation files and load the segmentations
and apply the intial grooming steps
# list of shape segmentations
shape_seg_list = []
# list of shape names (shape files prefixes) to be used for saving outputs
shape_names = []
for shape_filename in file_list:
print('Loading: ' + shape_filename)
# get current shape name
shape_name = shape_filename.split('/')[-1].replace('.nrrd', '')
# load segmentation
shape_seg = sw.Image(shape_filename)
# do initial grooming steps
print("Grooming: " + shape_name)
# Individually crop each segmentation using a computed bounding box
iso_value = 0.5 # voxel value for isosurface
try:
bounding_box = sw.ImageUtils.boundingBox([shape_seg], iso_value).pad(5)
shape_seg.crop(bounding_box)
# Resample to isotropic spacing using linear interpolation
antialias_iterations = 30 # number of iterations for antialiasing
iso_spacing = [1, 1, 1] # isotropic spacing
shape_seg.antialias(antialias_iterations).resample(iso_spacing, sw.InterpolationType.Linear).binarize()
# Pad segmentations with zeros
pad_size = 5 # number of voxels to pad for each dimension
pad_value = 0 # the constant value used to pad the segmentations
shape_seg.pad(pad_size, pad_value)
shape_seg_list.append(shape_seg)
shape_names.append(shape_name)
except Exception as e:
print(e)
To find the alignment transforms and save them for optimization,
we must break the loop to select a reference segmentation
ref_index = sw.find_reference_image_index(shape_seg_list)
ref_seg = shape_seg_list[400].write(groom_dir + 'reference.nrrd')
ref_name = shape_names[400]
print("Reference found: " + ref_name)
Now we can loop over all of the segmentations again to find the rigid
alignment transform and compute a distance transform
rigid_transforms = [] # Save rigid transorm matrices
for shape_seg, shape_name in zip(shape_seg_list, shape_names):
print('Finding alignment transform from ' + shape_name + ' to ' + ref_name)
# Get rigid transform
icp_iterations = 100 # number of ICP iterations
rigid_transform = shape_seg.createRigidRegistrationTransform(
ref_seg, iso_value, icp_iterations)
# Convert to vtk format for optimization
rigid_transform = sw.utils.getVTKtransform(rigid_transform)
rigid_transforms.append(rigid_transform)
# Convert segmentations to smooth signed distance transforms
print("Converting " + shape_name + " to distance transform")
iso_value = 0 # voxel value for isosurface
sigma = 2 # for Gaussian blur
shape_seg.antialias(antialias_iterations).computeDT(iso_value).gaussianBlur(sigma)
# Save distance transforms
groomed_files = sw.utils.save_images(groom_dir + 'distance_transforms/', shape_seg_list,
shape_names, extension='nrrd', compressed=True, verbose=True)
# Get data input (meshes if running in mesh mode, else distance transforms)
domain_type, groomed_files = sw.data.get_optimize_input(groomed_files, True)
print("\nStep 3. Optimize - Particle Based Optimization\n")
Step 3: OPTIMIZE - Particle Based Optimization
Now that we have the distance transform representation of data we create
the parameter files for the shapeworks particle optimization routine.
For more details on the plethora of parameters for shapeworks please refer
to docs/workflow/optimze.md
http://sciinstitute.github.io/ShapeWorks/workflow/optimize.html
point_dir = input_path + '/option_set'
if not os.path.exists(point_dir):
os.makedirs(point_dir)
# Create spreadsheet
project_location = input_path
subjects = []
number_domains = 1
for i in range(len(shape_seg_list)):
subject = sw.Subject()
subject.set_number_of_domains(number_domains)
rel_mesh_files = sw.utils.get_relative_paths([file_list[i]], project_location)
subject.set_original_filenames(rel_mesh_files)
rel_groom_files = sw.utils.get_relative_paths([groomed_files[i]], project_location)
subject.set_groomed_filenames(rel_groom_files)
transform = [rigid_transforms[i].flatten()]
subject.set_groomed_transforms(transform)
subjects.append(subject)
project = sw.Project()
project.set_subjects(subjects)
parameters = sw.Parameters()
# Create a dictionary for all the parameters required by optimization
parameter_dictionary = {
"number_of_particles": 512,
"use_normals": 0,
"normals_strength": 10.0,
"checkpointing_interval": 200,
"keep_checkpoints": 0,
"iterations_per_split": 1000,
"optimization_iterations": 1000,
"starting_regularization": 1000,
"ending_regularization": 10,
"relative_weighting": 10,
"procrustes": 1,
"initial_relative_weighting": 0.1,
"procrustes_interval": 1,
"procrustes_scaling": 1,
"save_init_splits": 0,
"verbosity": 0
# If running a tiny test, reduce some parameters
print('Generating project file')
# Add param dictionary to spreadsheet
for key in parameter_dictionary:
parameters.set(key, sw.Variant([parameter_dictionary[key]]))
project.set_parameters("optimize", parameters)
spreadsheet_file = input_path + "ventricle_option_set.swproj"
project.save(spreadsheet_file)
# Run optimization
print('Running optimization')
optimize_cmd = ('shapeworks optimize --progress --name ' + spreadsheet_file).split()
subprocess.check_call(optimize_cmd)
Run_Pipeline()
