The correspondence between my segments is very inconsistent, even when I re-run the optimization step with the same parameters. These are the parameters I have found to work the best and the results. Any advice would be greatly appreciated!
Hi there, I’m having a similar issue with my optimization of both pelvis and sacrum models. Any chance you have specific recommendations for pelvis and/or sacrum? Thanks!
I would suggest starting with a low particle count to begin with and make sure you can get a reasonable model there. You may need to use normals and/or geodesics to get a good model with these complicated and thin geometries. I know we’ve had success in the past with pelvis models, so I can ask around for particular parameter settings and get back you.
