I used Shapeworks to create a statistical shape model of cartilage. At first my input was binary segmentations but now I am using a different dataset which has .stl meshes. I didn’t want to change my pipeline so I tried to load the meshes and convert them to binary segmentations with shape_mesh = sw.Mesh(path_to_file) and then shape_seg = shape_mesh.toImage(). However, the meshes seem to get cut off on the sides. If I pad them, it just adds padding to the already cut off segmentations, is there any way I can avoid this?
Attached is an example of what is happening. The cropping is mainly visible on the left side of the segmentation.
Thanks!
