I am trying to create a model of vessels that have quite a bit of turtoisity.
You can see a sample from this picture.
I have done a parameter sweep over several parameter ranges, including: Geodisic distance, Normals, Procrustes [scaling, rotation/translation].
Could you provide me with guidance for the preprocessing of the data and/or what parameter ranges I should explore?
I understand that I am stretching the remit of this tool, but it would be really helpful if it were possible to arrive at an initial solution, even if not perfect.
Finally, if necessary, I can share my dataset through email.
Thank you very much,
Best wishes,
Simão
This is going to be a tough dataset.
Something I would probably try is to set a few key landmarks and use the geodesic distance from landmarks as a correspondence feature.
Is there a chance you could share some samples with me? amorris@sci.utah.edu
Hello Alan,
Thank you very much for the prompt response.
I will try placing landmarks.
Additionally, I have sent you a subset of the dataset to your email.
Best wishes,
Simão
Thanks, I’ve received them and tried some parameter sets, but so far not finding a very good model. I’m still working on it.
If you try the development version of ShapeWorks, you might find the registration initialization helpful for this dataset:
I used:
